4.6 swap
Old Dec 4, 2017 | 04:33 PM
elko08's Avatar
Smile 4.6 swap
I have a 2008 F150 with a 4.6 engine that my brother ran out of oil. I have a screaming deal on a 4.6 out of a 2007 crown vic police car. What are the complications of interchanging them and is it possible?
Old Dec 4, 2017 | 05:10 PM
Should be a straightforward swap. You will need to use the truck intake and exhaust manifolds, I'd also look at the oil pan and oil filter mounting.
Old Dec 5, 2017 | 12:04 PM
elko08's Avatar
Thanks for the input. I pick it up this weekend.
Old Dec 5, 2017 | 02:24 PM
dewalt17's Avatar
As long as the block is the same, shouldn't be much to worry about. I cannot remember what had Windsor or Romeo blocks, and when. Should be a wiki page on it somewhere. You will need to use your motor mounts.
Old Dec 5, 2017 | 02:42 PM
Romeo and Windsor are interchangeable as long as you don't try to swap heads or some internal parts.
Count the bolts on the driver's side valve cover - Romeo has 11, Windsor has 13.
Old Dec 5, 2017 | 04:00 PM
dewalt17's Avatar
Front cover and accessories are different, aren't they?
Old Dec 5, 2017 | 04:53 PM
Here are the basic differences in Romeo and Windsor engines:
# Romeo was the only Modular engine plant from '91-'95.
# Windsor came on line for '96 to build 4.6L and 5.4L SOHC engines for trucks and vans
# Although Romeo is primarily a car engine plant, it has produced Modular engines for trucks
# Although Windsor is primarily a truck engine plant, it produced Modular engines for '99-'00 Mustang GT
# Romeo engines employ different blocks, heads, and cranks than Windsor although they look similar
# Most Romeo blocks are marked with an "R" in the casting
# Windsor blocks are all marked with a "W" in the casting in two places
# Romeo heads employ bolt-on cam journal girdles
# Windsor heads don't have cam journal girdles, just individual journals
# Because Romeo and Windsor engines have different timing cover/cam cover bolt hole sizing, it is best to use Romeo heads and blocks together and Windsor heads and blocks together
# Romeo blocks have jackscrew cross-bolted main caps
# Windsor blocks have dowel pin cross-bolted main caps
# Romeo engines have primarily six-bolt flywheel/flexplate flanges
# Windsor engines have eight-bolt flywheel/flexplate flanges
# Oil filter/cooling neck types vary depending on vehicle type
# Timing cover depends on vehicle type
# Romeo cam sprockets are zero-fit and slip right on
# Windsor cam sprockets are pressed on
# Romeo cam covers have 11 bolts
# Windsor cam covers have 13 bolts
# Difference timing covers for SOHC and DOHC
# Same basic timing chain/sprocket system for both SOHC and DOHC
# DOHC engines have secondary timing chains for secondary camshafts
# SOHC has a standard oil pump and DOHC has high volume
