loss of compression
Old Oct 1, 2017 | 06:02 PM
bp9696's Avatar
loss of compression
1998 F150 4.6 loss of compression in 4 cylinders every other one in the firing order. Driving down interstate at 70-75MPH and had vibration. Stop and would not idle. if you keep the RPMS at 3000 or high it will run. Any ideals on what to start with?
Old Oct 1, 2017 | 08:01 PM
How do you know it's losing compression? Please run a compression test on all 8 cylinders and post the results.
Old Oct 3, 2017 | 01:57 PM
rriddell's Avatar
loss of compression
I have a 2003 5.4 v8. 254445 miles.
Started running rough, similar to COP problem. Took it to my mechanic. He said I had low compression in #5 cylinder. No codes shown. Maybe a stuck open valve. Is there any way to unstick without replacing engine?
Old Oct 3, 2017 | 08:49 PM
Roadie's Avatar
I would put a compression gauge on #5 and verify the compression.
Old Oct 8, 2017 | 08:58 PM
bp9696's Avatar
2,3,5,and 8 o compression
1,4,6 and 7 90-100 compression
Put oil in cylinder and the cylinders with compression raised some while the cylinders with no compression did not change
Old Oct 8, 2017 | 10:33 PM
Roadie's Avatar
If those readings are correct, you have serious engine issues. May be time for a reman engine.
Old Oct 9, 2017 | 06:51 AM
bp9696's Avatar
Yep, that is what everybody else has said and no one has every heard of that before. I am just trying to figure out if it is worth tearing into it or just go ahead an buy a reman.
Old Oct 9, 2017 | 09:05 AM
Roadie's Avatar
The problems are most likely caused by the valves. If you pull the heads you may find the problems. If you are lucky, you might get by with getting the heads rebuilt/timing chains, etc.
Old Oct 9, 2017 | 10:09 AM
bp9696's Avatar
Thanks for the input Roadie, that is probably where I will start. Hopefully i can get a little lucky. I will follow up with an update after pulling heads.
