Anti Drain Back Filters
Old Dec 18, 1999 | 11:30 AM
Twisted99's Avatar
Post Anti Drain Back Filters
After reading the pissed on slap thread I was wondering if anyone had any experiences (Bad ones) with Mobil's new oil filters. I have read that they are considered fine filters. My problem is that the first time I used on in My 95 SHO Taurus I had a noise that wasn't there before. I had been using STP filters for this engine. The noise sounds almost like timing chain slap and goes away above idle..say just several hundred RPM above idle. It's similar to a valve tapping sound. Any thoughts as to the drain back valve or what could reasonably be the cause. I do have 115000 miles on this car. Just weird that the noise was only present after the oil and filter change...
Thanks, Jeff C.
Red 99 Lightning (Totaled)
Black 99 Lightning
White 88 SVO Merkur Xr4ti
Sand Gold 88 Xr4ti
Silver 95 SHO
Old Dec 18, 1999 | 01:58 PM
insect2's Avatar
Post
Hello Twisted 99: I have been using the new Mobil #1 oil filter and have no problems at all. I also use their Mobil #1 oil.
Old Dec 18, 1999 | 06:15 PM
stephen muscio's Avatar
Post
Same here both the Mobile 1 filter and 5w30 oil and no problems.
Old Dec 18, 1999 | 11:26 PM
Rich's Avatar
Talking
You know, Now I know I am not crazy. After I changed the oil and filter on my 96 F150, I noticed the same noise, and it goes away just above idle. I have 79k on the motor. I have changed the oil twice, since I acquired the truck a while ago. The filter I use is the Motocraft filter. I think I am going to go back to the Fram, and see what happens.
Old Dec 19, 1999 | 09:56 AM
ps398's Avatar
Post
There was thread on here a while back that linked to a page that had oil filter comparisons on it. they showed cut apart filter so you see what was inside a how they were put together. Fram was not favorably rated. I went to the Mobil 1. it was rated the best by the site and seemed to be made better than most of the others.
[This message has been edited by ps398 (edited 12-19-1999).]
Old Dec 19, 1999 | 01:42 PM
Dustoff's Avatar
Exclamation
Rich..
I would NOT recommend going to the FRAM filter ( PH-2 for the F-150)! The one time I used it on my 98 5.4L F-150..I had a great deal of chatter at start up. When I switched back to Motorcraft..the noise was gone and never returned. Many other F-150 owners have experienced the same problem with FRAM filters. Bosch filters are very good..I have used them recently.
I was one of the individuals who cut open a PH-2 FRAM filter (also Bosch # 3410, Motorcraft FL-820S, and Deutsche #? )...and I will not use FRAM again until they get rid of the 1) plastic anti-drain valve and the 2) cardboard end caps. I have been using FRAM filters for many years in our cars..but not anymore. They are pure junk when compared to all of the other filters on the market today!!!
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old Dec 19, 1999 | 10:45 PM
WWBF150's Avatar
Smile
Here is the site for the oil filter tests/ratings. Enjoy. http://minimopar.simplenet.com/oilfilterstudy.html
Old Dec 20, 1999 | 05:17 PM
BLACKENEDFORD's Avatar
Cool
Hey Twisted, I had a 95 SHO but traded it in because it kept stalling on me. No Ford dealership in the state of Conn. could fix it. Have you had any similar problems?
Old Dec 20, 1999 | 10:28 PM
Rich's Avatar
Talking
Hey there blackendford, Where abouts are you located in Ct? Your the first person I've seen on thelist that is in Ct.
Rich
Old Dec 21, 1999 | 04:59 PM
Rich's Avatar
Smile
Blackendford,I am from stratford, down along I-95, Cool
Old Dec 22, 1999 | 12:00 AM
Post
Hey Rich, Im from Woodbury. About 15 miles west of Waterbury. How 'bout you?
1999 F150 4x4 XLT BLACK ORP 4.6 5 SPEED 3.55
LUND HOOD SHEILD
K&N
FLOWMASTER SERIES 40
PREMIUM SOUND W/CHANGER
PIONEER 6815's(for now)
