1997 idle problems
Old Oct 13, 2015 | 01:18 AM
C0DY F1N3H0UT's Avatar
1997 idle problems
I have a 1997 Ford F-150 with a 4.6L V8 with 178895 miles. Recently, when I start it up it idles fine for a few seconds and then drops down to about 300-400rpm. When the gas gets pushed it hesitates slightly but then revs up just fine. When I'm driving it works great but when I brake the rpms start to fall down to around 350rpm and then once I come to a complete stop it bounces between 350-600rpm. What could be causing it? I think it could be the fuel filter but I'm not 100% sure. Any suggestions on what could be wrong??
Old Oct 13, 2015 | 06:45 AM
projectSHO89's Avatar
It's the time of year for IAC valves that are sticky to manifest.
Clean the IAC valve as a temporary fix to see if it helps, replacement is usually necessary, though, for a more permanent solution. Also, check for intake vacuum leaks as they will make the IAC's function ineffective even if the IAC is properly operating.
Old Oct 14, 2015 | 01:08 AM
Ok I'll clean the IAC valve and check for vacuum leaks and see what happens. Thanks for the help
Old Oct 17, 2015 | 12:52 AM
Ok so I changed the IAC valve and checked for vacuum leaks and it's still doing the same thing. What else could be wrong with it??
Old Oct 17, 2015 | 08:24 AM
Did you THOROUGHLY check for vacuum leaks including the complete PCV system?
Is the MIL on and are there any DTCs?
Old Oct 17, 2015 | 05:42 PM
Update: I cleaned the MAF and the throttle body and it's running smoother, just at a low rpm. It still bogs down and almost dies if I'm braking and climb over anything. I check for vacuum leaks often and haven't found any. The check engine light is off, and I'm taking it soon to scan for codes
Old Oct 17, 2015 | 09:04 PM
If the MIL is off, there will be no codes.
Old Oct 19, 2015 | 12:50 AM
Is it possible that the new IAC valve needs to be adjusted?
