07 f150 no power
Old Sep 22, 2015 | 09:48 PM
Fordfan.2012's Avatar
07 f150 no power
I have a 07 f150 with 5.4 3v when accelerated the rpm's goes up but does not go up on speed (fastest was 20 mph) any help?
So far replaced:
Throttle body
Fuel pump
And computer
Old Sep 22, 2015 | 10:02 PM
Lewissa81's Avatar
Rpms increase, speed does not? That sounds like a transmission/torque converter issue.
Old Sep 22, 2015 | 10:10 PM
Thanks for answering and the rpm's don't shoot up they take a while to go up no matter how much you push the pedal and it stops around 3000
Old Sep 22, 2015 | 10:16 PM
Lewissa81's Avatar
Gotcha
How many miles are on the truck, and how old are the plugs?
Do you have any codes being thrown?
Was the problem there before you replaced the throttle body?
Have you cleaned or replaced the mass airflow sensor?
Have you checked for vacuum leaks?
Old Sep 22, 2015 | 10:30 PM
Gotcha
Motor has about 60,000 miles no codes being thrown and no problem with throttle body before and there's a hiss coming from the drivers side engine will clen maf tommorow I was also told it can be the drivers fuel pump module can this be true?
Old Sep 22, 2015 | 11:11 PM
Roadie's Avatar
That Hiss is a big clue. You need to find out what it causing the hiss.
What CE codes?
Old Sep 22, 2015 | 11:28 PM
What CE codes?
No codes showing up
Old Sep 22, 2015 | 11:44 PM
Lewissa81's Avatar
It's possible that the FPDM is the culprit, but I doubt it. It wouldn't cause the engine to flatten out like that. Easy to check though. Drop the spare tire, and take it off the frame. If it's corroded real bad, replace it. If it only has a little corrosion, but no breaks or holes or anything, then it's probably fine.
I'm inclined to agree with Roadie, the hiss is a big clue! Sounds like you have a vacuum leak. If you didn't already, replace the throttle body mounting gasket (it's only a few bucks) and make sure the throttle body is torqued down properly. If that doesn't help, get a propane torch and check for vacuum leaks.
Old Sep 23, 2015 | 12:29 PM
I'd suspect clogged cats or another major exhaust restriction.
