99' F250. Which engine?
Old Apr 28, 2015 | 07:56 AM
mymustang44's Avatar
Hi guys,
I'm really hoping someone here can answer this for me.
Short version is, my F250 has the 235hp version of the 5.4 L code, and I'm wondering what engines are direct replacements for my truck? I'd love to get the newer version(ie. 00-04), but I'm not sure what all would transfer or if it's even worth it.
Also, everywhere I look it lists pre 8/98 and post 8/98 5.4. How do I tell which I have?
My truck has blown the passenger head gasket and manifold gasket, and has 220k on it, so I figure I can replace the engine for about the same as paying someone to replace my head gasket.
Thanks in advance guys.
Old Apr 28, 2015 | 08:48 AM
HardmanGT's Avatar
the difference is the PI (performance improved) heads, cams and intake manifold. The pistons were also revised for the new heads.
You can swap a complete PI engine (post 8/98) in for sure
You can also do a PI top end swap on to your 97 and get a little better power. The compression will be higher than either the PI or non PI due to the pistons and smaller combustion chambers of he PI heads. Do a search and you can find more information about this.
Old Apr 28, 2015 | 09:19 AM
Good to know. Since mine is the cutoff year, how can I tell which engine I have by looking at it?
Also, forgive me if I'm wrong, but are you Bill Hardman by chance?
Old Apr 28, 2015 | 10:51 AM
The 235 hp version is non-PI. The PI engine is 260 hp.
Old Apr 28, 2015 | 11:23 AM
I understand that much, and I'm fairly certain that mine in the non-pi at this point.
I'm really looking for like a picture of the two to know for certain, as well as wondering, if mine is in fact a non-pi, what all would I need for a full pi engine to be installed, or will it be a direct drop in?
Thanks, guys
Old Apr 28, 2015 | 01:03 PM
The PI would need to be installed with PI intake and exhaust manifolds. I don't know what would have to be swapped over from the old engine but as far as bolting up there's no difference that I'm aware of.
Old Apr 29, 2015 | 07:13 AM
Thanks. Will it require a tune?
Old Apr 29, 2015 | 10:56 AM
I don't think so, but it sure wouldn't hurt.
