engine stalls when put into gear
Old Mar 8, 2015 | 01:32 PM
adamoutdoors's Avatar
2006 f150 fx4 stalls when put into gear when up to temp. when it is cold I can drive it fine. once it warms up it will stall if I don't double foot the gas and break when turning or at a stop. ive changed MAS, crankshaft position sensors per the codes. also cleaned my throttle body. not getting any better.
Old Mar 8, 2015 | 04:02 PM
What exact codes do you currently have? By the numbers, please.
Old Mar 11, 2015 | 12:17 PM
P2104, p2111 also changed fuel pump driver module and throttle position sensor, now won't start.
Old Mar 11, 2015 | 02:50 PM
0 P2104 Ford Comments | Add Comment
Tech notes
The P2104 code is an informational code only and may set in combination with a number of other codes which are causing the Failure Mode Effects Management (FMEM). If other codes are present, diagnose other codes first.
What does this mean? What does this mean?
When is the code detected?
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light
P2104 Ford Description
The Throttle Actuator Control (TAC) system is in the Failure Mode Effects Management (FMEM) mode of forced idle.
Read more: http://engine-codes.com/p2104_ford.html#ixzz3U6WyzfeU
5
0 P2111 Ford Comments | Add Comment
Possible causes
- Throttle Body Plate Binding
- Faulty Throttle Actuator
- Throttle Actuator harness is open or shorted
- Throttle Actuator circuit poor electrical connection
Throttle valve locked during Engine Control Module (ECM) order to close
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P2111 Ford Description
The throttle actuator is operated by the Engine Control Module (ECM) and it opens and closes the throttle valve using gears. The opening angle of the throttle valve is detected by the throttle position sensor, which is mounted on the throttle body. The throttle position sensor provides feedback to the ECM to control the throttle actuator and set the throttle valve angle in response to driver inputs.
Read more: http://engine-codes.com/p2111_ford.html#ixzz3U6X8TPt0
What does that tell you? Your throttle plate is binding, the throttle body motor is shot, or you have a wiring issue. You may need a new throttle body.
Old Mar 11, 2015 | 03:00 PM
The throttle body moves when starting but the engine will not start.
Old Mar 12, 2015 | 02:43 AM
toshortofnam's Avatar
Could low trans fluid make a f150 stall when put into gears?
Old Mar 12, 2015 | 06:24 AM
JCR 56's Avatar
no.
Old Mar 12, 2015 | 09:02 AM
Plenty of tranny fluid. Changed throttle position sensor and now won't start, gonna put the old one back on to see if the new one is junk. Otherwise, new throttle body?
Old Mar 12, 2015 | 12:45 PM
It may just be the actuator - or its wiring.
Possible causes
Old Mar 12, 2015 | 07:08 PM
So I got a functioning tps, starts but still stalls when in gear after warming. I'm lost and sick of dumping $ on sensors that don't help.
Old Mar 12, 2015 | 07:09 PM
And no codes
