Check this out!
Old Dec 7, 1999 | 11:18 PM
54regcab's Avatar
Question Check this out!
Tell me what you think about this thread.
It's in the exhaust forum but I thought I would bring it over here where everyone could see it.
cujet
Member posted 11-04-1999 10:43 AM
I just read in mustang and fast fords mag a very informative article about the 4.6l engine (Dispelling modular myths). The long and short of it is that bolt ons just do not help this engine due to the fact that the heads are the restriction in the airflow path. The ford engineer Andy Schwartz has the experience to back up his claims!
Quote "exhaust is a waste of money" "the 2 valve engine needs heads and intake manifold"
Headers = 2 to 5 hp
aftermarket mass air meter 10 hp $400
I installed headers, gibson ex and KN filter with airbox mods and a chip: net result no significantly measurable change in performance. By that I mean at least a 0.2 sec increase in 0-60 or 1/4 mile.
1000 dollars for nothing! I wish I had known before I purchased the stuff.
So now you know the real truth, with out FRP (svo) heads and an intake or a blower the 4.6l is not responsive to bolt ons.
Chris
ps. the fuel economy is lower also, down to 14.3 hwy and 10.7 city from 17+ hwy and 13city
Oh yeah I was stupid the day I posted this and mis-spelled benefit, However I could not figure out how to edit the header on the post.
98 SC 4.6L stepside, Gibson headers, Gibson single exhaust, superchip, Intake mods, Piaa's, high end audio stuff.
[This message has been edited by cujet (edited 11-07-1999).]
IP: Logged
spaceace
Member posted 11-04-1999 10:50 AM
FINALLY someone else that recognized NO gain from the airbox mods and freer exhaust!!!!
Standing by with the fire extinguishers.
1999 F250 SD CC, LWB, 5.4L, Auto, 3.73, 4x4, Power TT mirrors w/ marker lights, White, Full Tint, PendaPro SR, Flowmaster Delta 40 series, K&N filtercharger, Superchip(Airbox removed for a second try, maybe in the winter it will be advantagous?)
IP: Logged
cphilip
Member posted 11-04-1999 11:51 AM
Didn't expect much either. Snake oil comes in all kinds of packages. So instead of making decisions based on performance expectations I went for looks, sound and any cheap "no hurt" alternatives I could find. In that order. You can't be disatisfied if you don't get your hopes up too far. Yes, indeed, the flames will come!
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels and the 4X4 decals, MODs so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps.
IP: Logged
Sycoholic
Member posted 11-04-1999 06:43 PM
What, who buys exhaust for power. I always buy loud exhaust to turn heads and make people see how beautiful my truck is.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Chrome Grizzly Wrap Around Push Bar, Ford bedliner, Code Alarm Sure Start RVS remote starter, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
IP: Logged
BigRed2
Member posted 11-05-1999 08:30 AM
Are we comparing a 4.6 in a Mustang to 4.6 in a F-150? Aren't the heads and the intake different? Would the intake on the F-150 fit under the hood in a Mustang. I haven't timed my truck after the mods, but I make it up the hills easier and quicker without down shifting. Just my .02 worth, just a reminder to disconect the battery after each mod, this does make a difference.
IP: Logged
cujet
Member posted 11-05-1999 09:47 AM
Bigred2 you are correct the heads might be different depending on year and the intake is different. Even the pistons are different. However the differences do not help power output. floating piston pins do nothing for flow rates in the head and do nothing to the compression ratio. The intake is longer for more low end and is quite restrictive. the heads may or may not have minor changes in them for smog reasons and do not have the bigger valves, bigger ports and unshrouded and repositioned intake valves that are necessary for HP. In short it has the same performance and same smog stuff an the stangs
Chris
IP: Logged
cphilip
Member posted 11-05-1999 10:45 AM
I believe the floating piston pins are only in the windsor version of the 4.6L anyway but you are correct they do nothing for HP.
IP: Logged
Jason Langston
New Member posted 12-06-1999 12:00 AM
First of all anyone who thinks by installing any combination of bolt on parts they will have an instant hot rod pick-up is mistaken. Bolt on mods are not going to make a 15-16sec 1/4 mile pick-up into a fire-breathing monster truck. They are only to give that small (not a seat of your pants) improve on overall performance. Without dyno reading and/or 1/4 mile times the gains may never be seen. thats my 2 bits.
IP: Logged
cujet
Member posted 12-06-1999 10:28 AM
Jason, I did not expect 50 horsepower by the various mods I have done, however the fact that no gain WHATSOEVER resulted from the mods is troubling. I do have experience and know how from 25 years in the race car business (IMSA and SCCA). I also spent quite a bit of time recording and posting the results of each mod. What I have found is EXACTLY what Ford engineer Andy Schwartz says in the MFF mag. I believe that many trucks and cars respond in a much more favorable manner to mild mods. A few examples, Jeep gramd Cherokee V8, Dodge Dakota V8, older Chevy pickups with V8's ALL PICK UP HP WHEN PROPERLY MODIFIED! The ford 4.6l does not! Did I expect more power, you bet! My truck runs out of steam at 4500 RPM, I was hoping to extend the powerband to above 5000 RPM. The new 'stangs (with the updated heads) rev right past 6000 RPM.
Call me an idiot but past experience led me to do these mods, and I expected similar results to what I have had in the past, a freer revving more powerful truck.
Chris
IP: Logged
ps398
Member posted 12-06-1999 10:45 AM
You won't get flamed by me because you have discovered what drag racers have known for years. One of the most important peices on a drag engine is the heads. The big carb and cam, and thee fre flowing intake and exhaust will not do you any good if is all restricted in the heads. Now I am not saying that bolt on will not make any difference. Some should make a bit of differance but not a huge one. But I am willing to bet that if the only bolt on you added was a free flowing set of heads and NOTHING else most of you would be in shock the first time you mashed the gas pedal. Sorry to be so long winded and I am NOT knocking bolt ons. I have added some to my truck. The point is I don't expect exhaust and an airbox mod or adding an Airaid or similar setup to make a huge difference. I am surprised that your chip didn't more of a difference. To everyone alse if you want the stuff go for it! I will probably be right beside you in line But like someone said previously don't expect your truck to magically tranformed into an instant hot rod.
[This message has been edited by ps398 (edited 12-06-1999).]
IP: Logged
54regcab
Member posted 12-07-1999 11:15 PM
I wish this topic was in the aftermarket or engines section where everybody would see it.
There IS however a VERY noticeable differnce between the 5.4l and the 4.6L.
Best $800.00 or so performace mod going.
IP: Logged
99 XLT 5.4L reg cab 4x2 120" Wheelbase 4 wheel disc brakes/ABS 5 star larait style wheels Toreador Red/Silver 3.55 gears 255/70/16 OWL Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)powered by a Sherwood 35x2 RMS amp
Jensen 50x2 RMS for the 2 Audiobahn AWC10 subs
Looking for reasonably priced used running boards
regcab54@sc.rr.com in Columbia SC
Old Dec 8, 1999 | 02:01 AM
nomo's Avatar
Post
The intake & exhaust systems are substantially different between trucks and cars- with the Mustang having better "performance" systems to start with. We would see an improvement (in speed) by just bolting on the Mustang parts. Therefore, these test results have little meaning to truck owners. IMO
Old Dec 8, 1999 | 03:35 PM
BigRed2's Avatar
Post
It didn't work for Cujet, but my seat of the pants tells me mine has payed dividends.
I started with just the K&N, very little gain, but some. Next SuperChip and noticeable gains not only in shifts, but overall acceleration too. Next 3" single Cat-Back gained in more responsive acceleration especially at 1500 RMP and above. Last I modified the air intake, increased the incoming snorkel to 3" and removed the silencer out of the elbow. This was the frosting on the cake lost a little on the low end, but 1500 RMPs and above she really rips. I agree there is a point of diminishing returns and for me here on out gains will be hard to come by with out major $ mods. I am debating heads ported/polished or super charger any thoughts are welcome.
Just my .02 worth
99' F-150 XLT SC 4X4 ORP LS 4.6L K&N Air Filter Air Box Mod (3" intake from fender & silencer removed), Superchip, A.R.E. Cover, Duraliner bed liner, Rapidflow 3" single CatBack exhaust.
