5.4L New Reman Engine Problem
Old Feb 26, 2014 | 10:52 PM
AugustinFx4's Avatar
Hello guys,
I have a 2006 Ford F150 Fx4 with the 5.4L engine & auto trans. I put new:
- engine new-remanufactured
- intake manifold
- injectors
- coils
- sparks plugs
- water pump
- power steering pump
- cam&crank sensor's
- Pcv electronic
- harmonic balancer
- starter
- belt, pulleys, etc.
I have engine light On with P0018 code, engine is vibrating at idle. It's running up to one minute and stops.
Any suggestions?
Old Feb 26, 2014 | 10:55 PM
The engine is a long block with vct and valve covers(advancedenginex). I changed the crank shaft sensor but I have the same code/vibration. P0018 - Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
Where is located the bank 2 Sensor A?
