HELP! Truck won't start when hot outside
Old Sep 28, 2013 | 09:38 PM
KLacey's Avatar
My '98 F150 4.6 V8 runs fine when it is cool outside. When it is hot outside(above 90 F) and the motor is warm (after a few minutes of driving) it runs fine. But if I shut off the engine, run it to a store for a snack, and come back to leave the motor will not start. The motor sputters a little like it wants to start but the RPM aren't high enough. It gets stuck in a very low idle for a few seconds then dies. If I let the truck sit for about 40 minutes and cool down it will start up again.
The starter will turn and it is getting spark. I think it has to do with fuel.
Questions:
Has anyone else had a similar problem?
Is there some part of the fuel system that would fail due to heat?
-The guys at Autozone suggested that the fuel pump could be the culprit, but I have never heard of one failing from the heat.
Any info helps
Kyle
Old Sep 28, 2013 | 10:43 PM
jethat's Avatar
Get a fuel pressure gauge. Make sure the filter is good. Test the pressure. Should be over about 30 psi minimum but check and find out what the exact spec is.
