2003 F-150 4.6 Accessory Belt part #
I have 2003 F-150 4.6 w/ AC.
For accessory belt www.motorcraft.com gives me JK6-996E as a part number.
However, if I check the http://www.fordinstallersupport.com/...s/belthose.pdf I'll get JK8-996-AA as a part number.
Amazon tells that JK8996AA fits my vehicle, but for JK6996E it tells that it won't fit.
I know that Amazon is sometimes unreliable, but Motorcraft should know better.
Which one is the correct part number? Should both fit?
Just look under the hood, - Alternator is right there. See if it has the 6 or 8 rib. I'm guessing it has the 6 rib,- could be 8 tho.
But yea, -easy to confirm yourself just looking at it. Unless you can't count that far..
When I plug the Motorcraft # into the dealer site here ---> http://www.bluespringsfordparts.com/...150-parts.html
It says that it doesn't fit that application...
I think Amazon is right about the second part. Try searching that site to see.
Thanks - yes, my truck is 6 rib, so JK6996E will be a belt for my truck.
I can count at least to 10 as I have 10 fingers
but I could not decode Motorcraft part number. Now it is obvious that JK6 is for 6 and JK8 is for 8 rib pulleys
Also I did not realize that 8 rib pulleys were a factory option for F-150 4.6 XLs!
Yea, 8 ribs were for the larger amp alternators, like say for municipal vehicles that need the extra amps. Police vehicles, ambulances and such. They must have been a available option for your model year.
A large amp alternator requires better traction, more engine power and a belt that won't slip which is where the 8 rib is necessary.
