Where is the Engine Code?
The 8th digit off the VIN will only tell you manu. location and size of the engine the was originally installed from the factory. Compare that information to the engine code on the driver side valve cover. If the engine has been replaced, you most likely will not have any information on that valve cover. A FQR will have a Ford Quality Renewel sticker on the top, rear passenger side valve cover. A Ford Remanufactured will have a metal tag attached to the BLOCK right above the rear side of the oil pan also on the passenger side. Hope this helps.
