Starter
Old Jul 8, 2013 | 04:15 PM
Expedition5.4's Avatar
Starter
When I bought my truck in April 2012 the starter was replaced. (so they said)........
anyway, I just replaced the starter myself 2 weeks ago and it is acting up yet again, doing exactly what it did before spinning but not engaging till after a few try's. I also replaced the solenoid on the firewall when I changed the starter.
What could the problem be? Why would it keep doing the same thing?
Old Jul 9, 2013 | 08:15 AM
JCR 56's Avatar
Take the starter back where you got it and have them replace it. Sounds like a sticking starter drive.
Old Jul 10, 2013 | 10:52 PM
jethat's Avatar
Did you check the ring gear on the flywheel? could be damaged/worn out..
Old Jul 11, 2013 | 11:47 AM
Need4racin's Avatar
cheap autozone made in china starter. get one of these. http://www.rjminjectiontech.com/collections/starters
Old Jul 11, 2013 | 01:02 PM
jethat's Avatar
Ford starters are pretty good. I've replaced a couple in my day but the problem always ended up being something else when I did replace them. Now I know if your throwing parts at it make the starter the last thing..
Old Jul 16, 2013 | 01:41 PM
I took it back they gave me a new autozone starter and it seems worse now someone said it could be the flywheel What do you all think
Old Jul 16, 2013 | 02:10 PM
jethat's Avatar
Yeah that's what I said... Take the inspection cover off and look at it you have to remove the transmission to replace the ring gear on the fly wheel.
