HELP !! Cooling system Flush 2001 SCREW
Old Jun 11, 2013 | 11:41 AM
rjfal's Avatar
Good morning All,
A few years back I found a thread with detailed pics and instructions on how to flush my cooling system ( '01 Screw 5.4 ). I've searched high and low and cant find this thread. Does anyone have it or can someone post a link to the thread. Need to do a flush and thermostat change this coming weekend.
btw - whomever decided to make a forum for F-150's - you are a god !! - I have found tons and I do mean ton's of helpful info on this over the years.
Thanks !
Old Jun 13, 2013 | 02:43 AM
code58's Avatar
I have one piece of advice. DON"T use a coolant flush unless you are POSITIVE it doesn't have corrosive (acid) cleaner in it. It will eat your radiator out before your eyes!
Old Jun 13, 2013 | 04:15 AM
jaws12's Avatar
There should be two block drain plugs on either side of your engine, and the pet**** of your radiator. Stick your water hose in the overflow tank and open these three plugs. The water will flush out any junk, rust whatever. You can add some coolant flush but I have little experience with it. After that start adding distilled water and coolant. I've always used well water, but others will say used distilled water.
Old Jun 13, 2013 | 09:47 AM
ishootstuff's Avatar
LOL. Can't say C 0 C K. What if we need to discuss roosters?
Old Jun 13, 2013 | 09:57 AM
Then refer to it as a male chicken!
Old Jun 13, 2013 | 02:55 PM
rjfal's Avatar
Weekend Project this Saturday !!
All - I'll let you know how it goes. Anyone know the mixture ratio ? I'm in CT and it gets cold here
Thanks !
Old Jun 13, 2013 | 04:32 PM
grizzstang's Avatar
Antifreeze / Water
60 / 40 roughly
You would be better off testing it to know for sure. Figure what temp you are comfortable with. I like mine to be good to -40 degrees minimum. I can't remember the last time it got that cold here but it has come close and better safe than sorry.
