1998 4.6 200,000+ Miles Factory Oxygen Sensors
Old Jun 1, 2013 | 12:44 PM
OldeIron's Avatar
My 1998 F150 4.6 has almost 220,000 miles on it. I have replaced lots of parts over the years as trouble codes popped up or as needed. But I have never replaced the factory oxygen sensors. I bought my truck with 50,000 miles so I don't think the previous owner replaced them.
I have never had a O2 trouble code pop up and fuel mileage has always been a consistent 15-16 MPG. So my question is this: is it necessary to replace them even when everything seems okay, or should I wait till fuel economy declines, performance suffers, or an obvious O2 code flashes?
Old Jun 1, 2013 | 12:52 PM
I'd replace them.. I'm replacing mine in August and I'll have about 93k or so by then. I'm **** though haha
Old Jun 3, 2013 | 07:47 AM
jbrew's Avatar
With that many miles, you better at least crack the rears(downstreams) loose while she's running. DON'T force those too much, - very easy to trash the bungs on the way out. Add more heat to just the bungs at the same time,- if you have to. Once the bungs are screwed, it's a different ballgame that can cost you more than double.
The upstreams are always easier to loosen. Passenger side can be a PITA to manipulate, unless you have the correct Ford O2 sensor socket, but will loosen with less torque effort than the rears once in position.
