surge at idle in neutral, cuts out in drive
f150 02', 4x4, auto, 5.4l, 125, 000 miles. I ran out of gas a little while ago and right before I cut her off she gave a heavy idle surge as I pulled into the gas station. It would go up to 1500 rpm and drop as low as 400rpm, the truck never fully gave out of gas, I cut it off as soon as I rolled into the gas station. Ever since it has surged at idle and will cut off if it sits under 1000rpm for more than a few seconds. I have changed the fuel filter, cleaned out the mass air flow, sea foamed the motor, and just recently changed the IAC. I thought for sure the IAC was the problem it was real nasty when I pulled it off. I bolted up the new piece and attached the battery with no luck. I'm at the end of my list of easy things to try. . . Next is the fuel pump unless there are any folks on here that have another idea.
Broken vacuum line, go figure. I have had a time with it and just over looked the small stuff. Found the broken line replaced it and idles like a champ. Thanks for the input fellas.
