Ford Says I need a New Ford Long Block: 7,600
Check engine light came on after I was hearing a weird noise on acceleration, deceleration, stopping. Especially when stopping it sounded like something clanking underneath. I thought it was the cats. Anyway, long story short, they say it was way low on oil and oil pressure, and the rings are shot. They claim it will be more expensive to rebuild than to buy a long block. It is supercharged with 122k miles. But how do I know they are not full of it? What options do I have? Thx
What else do you need?
You could also get a second opinion from an independent shop. Perhaps you have a local "speed" shop in your area that has expertise in your configuration.
Sometimes, despite having done nothing obviously out of the ordinary, stuff just breaks. Luck of the draw.
With the supersharger etc., I suppose it may have caused premature failure. It runs fine since they put the 4 quarts of oil in.
at this point, might as well run it till it blows!
i have a question tho. how can they determine the rings are bad if they didnt take out the pistons?
That's what I wonder--how they know for sure. But no oil is leaking outside the block. It never burned oil before. Then suddenly it is down 4 quarts. When I drove it home it drove fine, but I am not driving it right now until I figure out what to do with it.
so another motor exactly like you have, probably isn't going ot accomplish anything but drain your wallet
go with forged internals and a real tune
