DTC P0118, in a 5.4 swapped 1998 F250
Got this truck for super cheap and it's run like a dog, previous owner swapped a 5.4 into it from a 98 expedition.
temp gauge works fine, I can see an empty plug on the harness under the intake snorkle, and I see a sensor tapped into the manifold that is plugged in.
From my reading I'm gathering that there should be 2 sensors here instead of just this one, does anyone have the part number for the missing sensor and what tap I need?
Or is it safe to just pull out the current sensor that I'm assuming just operates the temp gauge and install the missing sensor there?
T
T
