Water in gas????
Old Feb 25, 2013 | 10:22 PM
NKENN's Avatar
Water in gas????
2001 Excursion, 5.4L, 213K miles - We have been having excessive rain for the last few days and I filled up at my usual station. After driving for less than a mile the vehicle started running rough, felt like it was missing and loss of power. I called the station to advise them that I suspected that they have water in their gas and they advised me that they have two filters in their pump and that there must be something wrong with my vehicle. I thought filters only removed particulate matter. Does anyone know if gas stations use some kind of water separator in their filtering system??
Old Feb 25, 2013 | 11:06 PM
kingfish51's Avatar
They could. My guess is you have water around one or more of the COPs causing a misfire.
Old Feb 27, 2013 | 09:10 PM
NKENN's Avatar
My cousin was in the gas line directly ahead of me, her car is running rough now. Can anyone answer my original question?
Old Feb 27, 2013 | 09:41 PM
kingfish51's Avatar
Diesel vehicles have filters that trap the water, so the station could easily have them.
Old Feb 27, 2013 | 10:15 PM
jgger's Avatar
One of the local stations here had a driver put diesel in the station's tank. They bought a whole lot of cat converters for customers!
Pull your fuel filter and drain it into a glass jar, if you have water then you will see globs of water in the bottom.
Yes I think they can filter the water out before the pumps, but if they haven't serviced the system lately you can still pick up water.
I have also heard thet ethonol is more prone to water, but don't know for sure.
Put a bottle of HEAT in the tank, it will take care of water in the system unless it's real bad. It doesn't take much water to screw with things
Good luck.
