Found an engine for my swap. Thoughts?
I have mint 98 with a 4.6 with 87k.
I found a complete 99 5.4 with 98k. The engine looks to be well maintained (not filthy under the Hood, clean filters) but the Guy junked it when it started to miss(body badly rotted). One plug is blown out. The yard claimed to have run the engine for an extended period with no other issues.
$900 and they will properly fix plug.
I have been looking for months and this is the best I have been able to find within 100 miles.
Buy or walk?
Buy or walk?
That's a MUCH cheaper fix than $900. IF that's why it's misfiring. I'd check compression before purchasing. Just to get a consistency read.
Have you searched using car-part.com. They search for an engine for you, - from your area outward and that's a free service.
If they use a helicoil to repair it plan on it blowing again.. That's the way lots of mechanics do it and that is the WRONG fix.
They claim to have a special kit with a bit that gets hooked to a vac to remove chips as they drill. Then some sort of insert is used.
I'd question the insert and install method used tho. Specially not ever hearing of such a tool available for this type of repair.
As mentioned the 99 is a good year. Also a compression test is a good idea. I have heard of using a vacuum to suck out the chips as you cut. Never saw the tool though. I used a lot of grease instead.
Could of easily removed the head, - no need. Not yet anyway.
I bet your impressed...
Here's another option - a 2012 5.0L with only 8,700 miles http://stlouis.craigslist.org/pts/3582653557.html
Quite a bit farther away and twice as much $ as your 5.4L, but is practically brand new and comes with the 6spd tranny, wiring and PCM
This is not mine BTW, just saw it on CL today.
