Pulley whining, making noise, 2003 5.4L, 155,000 miles
I listened carefully under the hood and couldn't figure out where the whining noise was coming from. I took the belt off and started the motor and there was no sound, so I knew it was a pulley. Since the idler and the tensioner pulleys are easy to access and cheap, I bought them at AutoZone, replaced, and the noise is gone. wow, the truck really sounds good without the whine. For $18 each, you really should change them anyway.
The tensioner and idler are normal wear and tear components that SHOULD ALWAYS be changed when you change the serp belt. Although the tensioners only are recommended and published, you should catch the idler as well, since life expectancy is similar.
