How do you change the fuel filter...
Old Nov 1, 1999 | 01:17 PM
kkirt1's Avatar
Post
Search on "Fuel Filter". There are a couple of good topics on the subject.
You need a special tool to remove the lines from the fuel filter. Also, don't forget to relieve the pressure from the system before you remove the lines and wear some eye protection just in case.
Good luck and if you are still having problems let us know.
Old Nov 1, 1999 | 04:20 PM
Dewy's Avatar
Talking
Hey Thanks - I think I found what I need. This board is excellent! Thanks again!!
Old Nov 2, 1999 | 12:15 AM
Dewy's Avatar
Question How do you change the fuel filter...
Specifically - how do you disconnect the actual fuel lines from the filter. Do they "snap" on to the filter? If I pull hard enough will they come off or is there some trick to get them off. I couldn't get 'em to come loose.
TIA!
