check engine light
Old Oct 23, 1999 | 04:53 PM
Chuckk's Avatar
Post check engine light
I have a '98 Nastruck,25,000 miles and my check engine light is staying on. Called Varsity ford in College Station and they said to bring it in that it was emissions and no big deal. I have the B&M shift plus, is it going to mess with the computer when they run a check on it? Also I'm getting quite a bit of noise from the valve's. I notice it at idle and when I kick it into passing gear.(lots of clicking) What's up? I took the reducer out of the elbow,also have a flowmaster. I'm wandering if they are going to give me a hard time considering it's still under warranty. Can anyone help me? I'm really concerned about the valve's! Good to be back online!
Chuckk
Old Oct 23, 1999 | 11:44 PM
Sycoholic's Avatar
Wink
Really depends on the dealership. If they refuse to repair under warranty, ask them why. If they tell you it's because of a certain modification, ask them to tell you how this mod. caused the failure. If they still give you a hard time, try calling Ford customer service. I don't have the number, but I'm sure somebody around here does.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Chrome Grizzly Wrap Around Push Bar, Ford bedliner, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old Oct 24, 1999 | 03:12 PM
Alf Hayes's Avatar
Post
They think it's the gas filler cap. If it's not on tight the computer detects it and thus the check engine light. Just bought a Y2K on Sat, and the salesman warned me about putting the cap back on correctly after fill-up...
Old Oct 25, 1999 | 01:02 AM
hmustang's Avatar
Post
Thats one I never heard of before I think he was full of it when he told you about the gas cap.
Old Oct 25, 1999 | 02:08 AM
MrLarmo's Avatar
Post
Gas cap off can definitely turn the light on in newer vehicles. There's a pressure sensor in the fuel tank to monitor leaks in the system to prevent hydrocarbons from escaping. I'm not sure if this is a CA thing or 50 state.
Old Oct 25, 1999 | 03:23 AM
Dennis's Avatar
Post
Not sure about the newer models, but I do know, first hand, that the '97's Check Engine light comes on if you don't secure the gas cap.
Anytime that light comes on, check the cap first.
Old Oct 25, 1999 | 05:45 PM
hmustang's Avatar
Post
Okay now I know its true I did a test on my 96 Mustang this morning and sure enough the light came on after I took the cap off.
Old Oct 26, 1999 | 12:29 AM
dlsipe's Avatar
Registered User
Post
My 97 has had the light on twice. Both times for faulty Oxy. sensors. Out of warranty. Cost over $400 to replace both when cost is combined. (I have the 5.4)
97 F150 Lariat 4X4 Ext. Cab. 5.4, AT, Gibson Side Swept, K&N, Bosch Platinum +4's (Both doors cracked:-( )
Old Oct 26, 1999 | 05:04 AM
V10 man's Avatar
Wink
It's the gas cap alright.... I loosen my neighbor's 97 Chevy's cap all the time....He still hasn't figured it out...hehehe
Old Oct 26, 1999 | 10:39 PM
Chuckk's Avatar
Post
update! My truck when in the shop Monday morning. Today I was told I had a fouled plug. Something happened when I hit passing gear. Must have fouled the plug then,because the light came on seconds after that. I'm still waiting on the brakes,they didn't get to them today. The service manager told me that he thought I had antilocks front and back because my light on the panel says ABS instead of rear ABS,hope he's right! Hopefully I'll have my truck back tomorrow and have some brakes that are worth a dam.
Chuckk
Old Oct 27, 1999 | 01:48 AM
Dan Kvachuk's Avatar
Wink
My check engine light came on after vacuum loss in the fuel tank. Unfortunately, it won't go off now. I was told be the dealer this is a normal occurence if the gas cap is left loose. So, they tell me to bring it in and they'll reset the computer (for a mere $32.95). Isn't that nice? So, I'm thinking doesn't the computer reset by disconecting the battery? Or, can anyone else offer a suggestion so I can save $32.95. Thanks.
What does the guy who dies with the most toys really win?
Old Oct 27, 1999 | 08:10 AM
Tina's Avatar
Exclamation
dan K: Yes you can reset the computer and turn that lite out!! Just disconnect the battery and then turn on your head lights. Turning on the head lights drains whatever reserve power you have and resets faster so you don't have to wait as long to connect the battery back up. Takes about 1 min verses about 30 minutes. If your check engine lite comes back on, then that's a good indication that whatever the problem is, isn't fixed.
Old Oct 27, 1999 | 09:54 AM
cloaker's Avatar
Post
Tina, you should charge for that piece of advise!!!! good call! hmm, maybe tell people to buy the f150online sticker as your service charge!
I have been thinking about reseting mine since it ran better when it was reset the last time when I installed the chip..thanks for the info Tina! ps. I already have my sticker!
David
'99 F150 XLT SC, STYLESIDE
4X4 ORP 5.4L, AUTO,
139wb, Rhino, K&N,
BugGuard, RainGuards
Superchip
Old Oct 28, 1999 | 12:42 AM
Post
Thanks Tina! I'm pretty sure that will fix the problem. Running good; might be an o2 sensor. But, I only have 14K miles.(?) Thanks again. BTW, what's all this about a sticker?
Old Oct 28, 1999 | 09:45 AM
cloaker's Avatar
Post
Dan, go to the online store, you can purchase a www.f150online.com sticker to support this awesome site! GO NOW!
David
3.73, 4X4 ORP 5.4L, AUTO,
139wb, Medium Red Tor.,
Rhino, K&N, BugGuard,
RainGuards, Superchip
f150online sticker!!! GET ONE NOW!
