Coils
Old Oct 16, 2012 | 05:31 AM
nenee41's Avatar
Coils
I have an 04 5.4 (newer style ) fx4 . I changed the plugs about 40,000 kilometers ago . I am having the same issue I had before changing the plugs out . Shes missing under load . The coils have not been replaced ever . Truck has 200,000 kms . What I am wondering is, ford dealership or any parts store here in Atlantic Canada wants between 65-80 $ for each coil ..... I look on eBay and I find 8 coils for under 100$ . Has anyone ever run these cheap coils on their truck ? I'm thinking even if they only last 50,000 , I could change them out 4-5 times before hitting the 500 $ that the dealership wants . Any input would be great!
Old Oct 16, 2012 | 07:46 AM
People have had mixed results with the Ebay coils - but for the price it's worth a try. Buy from a seller that offers a warranty and get a V10 set so you have a couple spares. The 5.4 3 valve takes DG511.
Old Oct 18, 2012 | 07:07 AM
nenee41's Avatar
10 new coils ordered .. 120 $ with shipping. I'll update as to how they work for me .. Lifetime warranty btw .
Old Oct 18, 2012 | 08:45 AM
Be sure and use dielectric grease on the boots when installing. As for you current miss, it could be that the old boots needed to be replaced when the plugs were done. Also, the dielectric grease should have been used then as well. Cracked boots can cause a miss.
Old Oct 19, 2012 | 07:50 AM
jbrew's Avatar
To late now, -should of just purchased Visteon (Motorcraft) Coils. Cheap and no reported failures.
Oh well, next time maybe.
Good Luck.
Old Oct 19, 2012 | 02:54 PM
Haven't seen any Visteon DG511's in a while, just DG508's.
Old Oct 20, 2012 | 02:41 PM
jbrew's Avatar
Oh yea? They finally running out of them? That's to bad.
Curious how many have run them around here without a problem... ? Still,- a great deal for about 180 for a set. IF you can find them that is...
Old Oct 21, 2012 | 09:16 AM
Tschro's Avatar
Hey guys, what does "oem scratch motorcraft" mean? I found some coils online that are described that way. Thanks
Old Oct 22, 2012 | 09:07 AM
Supposedly, they are OEM coils that have had the Motorcraft ID's scratched off.
Old Oct 22, 2012 | 10:45 AM
Tschro's Avatar
would you buy those or the visteons?
Old Oct 22, 2012 | 11:55 AM
I'd buy the Visteons.
Old Oct 22, 2012 | 05:40 PM
Tschro's Avatar
ok. Thanks for your reply.
Old Oct 25, 2012 | 06:49 AM
nenee41's Avatar
Coils arrived yesterday . An hours work and 10 $ in grease and the problem is fixed. I hope they hold up . If not I still have a couple extra
Old Oct 26, 2012 | 02:03 AM
K.R.newbie's Avatar
I got a set from ebay too global auto. been in truck now a couple months now or more.
So far so good.
Old Oct 29, 2012 | 04:39 AM
jbrew's Avatar
I still have a couple extra Global coils in their boxes, -haven't had to use them yet. I installed this set back in 08.
Might grab a set of Visteon's (Motorcraft) before the next tune up, -since they can be had cheap. - Retire the Globals, or have them on standby, -just in case.
