Lube oil specifications
Old Oct 15, 2012 | 05:53 PM
LKG907's Avatar
I recently acquired an '06, 5.4L F150 and am a bit confused on the lube oil. I understand that the recommendation is 5-20, and that's a bit scary. But I'm uncertain on the rest. Semi-synthetic, Dino oil? What are most of you folks using? Thanks in advance.
Old Oct 15, 2012 | 06:11 PM
It's a 5.4 3v use the weight what's recommend on the cap.....either motorcraft semi syn or penzoil....along with a motorcraft oil filter....
Old Oct 15, 2012 | 06:21 PM
LKG907's Avatar
Penzoil
That's one of the problems. I can't buy 5-20 Penzoil around here in anything other than quarts. NAPA, Shuck's & Oriellies only have quarts available. No one stocks gallons or larger.
Old Oct 15, 2012 | 06:37 PM
sam1947's Avatar
You can buy 7 quarts.....????
Old Oct 15, 2012 | 06:51 PM
LKG907's Avatar
No. Only quarts.
Old Oct 15, 2012 | 07:05 PM
SubSkip's Avatar
Originally Posted by LKG907
No. Only quarts.
Psssst....the oil that comes in quarts is the same oil that comes in gallons.
Old Oct 15, 2012 | 07:24 PM
LKG907's Avatar
Yeah, but I'm cheap. It cost 50 cents more per quart if purchased in quarts. Plus, it's a storage problem.
Back to the original question. Semi-synthetic or not?
Thanks.
Old Oct 15, 2012 | 07:33 PM
Do you have a Walmart around there? They carry the Motorcraft semi-synthetic in gallons and quarts. That's the best oil for that engine and it's cheap. They should also have the FL-820S filters, again, the best for the engine.
Old Oct 15, 2012 | 09:45 PM
SubSkip's Avatar
All kidding aside, go with what glc said. Motorcraft semi-synth oil and filter.
Old Oct 15, 2012 | 09:57 PM
sam1947's Avatar
^^x2
Old Oct 15, 2012 | 10:57 PM
1LethalSVT's Avatar
LKG907 being cheap about the oil and these 3V motors don't mix. Buck up spend the extra coin. Like every one else said, get the Motorcraft semi-synth oil and Motorcraft filter.
