2002 5.4 - spark plug blow out
Time Sert kits are AWESOME!!
stamping on my head that is RF-2L1E and 14 valve cover bolts. is this a Windsor head? I was also told all 5.4 L engines are Windsor heads. I also was repairing a prior repair, I DID NOT use the counter bore tool in my repair. I went right to the reamer tool, I hope I did not make a mistake by not using the counter bore tool? The insert seemed to install correctly but I had no way to verify it, as the cylinder I worked on was a blind one, number 7 towards firewall.
