Codes P0171, and P0174 2006 4.6
Can't help if you don't answer the questions. I asked for EXACT rpms. You say it idles smooth. So what are the EXACT rpms ??
In order for him to tell us EXACT rpm's he would have to hook up an digital tach or have a tuning program capable of doing a data log, He mite not have either. 700-750 is what a factory tach would look like in that range.
Yeah I have no idea what the EXACT rpm's are.
I have inspected every vacum line & PCV line I can visually and they all look good. I also inspected the intake tubing after the MAF and all looks good.
Do I have to use a special wrench/socket to remove the o2 sensors?
Well, if your that lazy and can't even look, -then it's a good guess that you haven't done what's been questioned so far, -or what you say you have. Not thoroughly anyway.
Do you seriously want to fix your truck? I don't think so, not to seriously anyway. I mean common, that's just Lazy. No other word for it. Not sure what else I'm suppose to think here.
Idle rpm differences at closed and open loop can point a mechanic in the right direction,- to the problem part. Apparently you have some sort of problem just reading the rpm scale ?
Iduno, maybe you better take it in.
Good luck anyway, -yea start throwing parts at it, - you'll get there.
Still sounds like a air leak. I kept getting these codes on my Expd. Replaced and cleaned every thing. All new PCV, EGR, and IAC lines, new IAC, EGR, and PCV. Replaced S&B CAI with volante, thinking there was an issue with tubing. Also had a whistle. Truck ran and idled fine moost of the time with the occasional stumble when coming to stiop after running for an extended period. Ended up being a cracked intake manifold.
If the 2006 is the same as the 2003, you can use the digital odometer display as a tach. As I remember - press and hold the reset button, turn on the key, and hold till it reads "test". Repeatedly press the reset till it says "tach". Start the engine.
This is obviously a 4.2L, it shows the same type sytem the 06 has, -except for location, -
____________________________________
Plus it has the "drive by wire" system TB. I don't think it has an actual IAC anymore. Iduno, - haven't had the privilege yet lol.
BTW, It may have a heated PCV system like the 5fours. Those PVC systems look a little harder to work on, from the diagrams I've seen in the past. Not sure? Anyway, they looked to be heated differently tho , from 97-03 models.
So it's a little different to troubleshoot. I never liked the looks of the drive by wire get up. It looked like and invite for problems to come IMO.
Other than that, small tweaks to Emissions systems. Haven't heard of any difficulty's with those tho.
I do know those throttle body type motors @ the body can go bad. Something like that, -not sure if that's the proper terminology, - I've heard them called an actual tb motor mechanism.
So, he most likley didn't know how to bring up the rpm readout? That makes more sense.
So if insulting people makes you feel better about yourself have at it. I am just trying to fix my truck.
All the lines looked near new with no signs of deterioration.
Well, I guess I hadn't realized that you may not know how to read a tachometer.
Then again. If you do not,- it may be a better idea to just take the vehicle in and let the pros have at it.
Regardless, -good luck with her.
I agree. Specially with both banks testing positive for lean, - and at the same time. If the OP would post EXACT idle rpms @ operating temp in park, it would be much easier to diagnose. But hey, sounds like he has plan set in mind. Maybe we'll get to see how that pans out for him jgger.
Now I I'm not sure what line it is for replacement. Damn near split right in half. leads to the intake manifold from some module right off the brake master cylinder. Just damn glad to know what it is after 2 months.
