Vacum hose on 2000 5.4L ID
Started pulling parts off the truck to give it a good tune up and replace plugs, cop boots and the like since I`m giving the truck to my daughter. Upon pulling the TB cover off I found a problem right away. The rubber hose from the nipple on the rear of the throttle body to the firewall connection with green connector is trash. It has just disintegrated with the engine heat and age and I need a new one. I looked at multiple parts books and cant find a ID for it anywhere. Anyone have a clue as to what its called so I can get a order placed for one?
Picture shows the hose in question outlined in green...
Evap return tube.
Dealer part only? I dunno. Don't see it at rockauto
part number 9G271 I believe.
You can probably replace it with fuel hose of the same diameter? If the fitting on the end is in good shape and will allow it.
Maybe jbrew will know where you can get one
Wow...Thanks for all the help and replies guys. I was hoping to find it online from discount dealer parts as that pricing always is cheaper than my local dealer. On this I may just have to get it directly from them so they can look it up in there book.
Thanks again
Toyz..Thanks for that number as I was able to find the following now since I knew the name..So if anyone has the same issue...Not cheap either...
Item Callout: 9D289
Manufacturer: Ford
Brand: Ford Genuine Parts
Catalog Description: Tube Assy - Fuel Vapor Separator
Part No.: F75Z9D289AA
1997 Ford Expedition 4.6 8 Cyl
1997 Ford Expedition 5.4 8 Cyl
1997 Ford F150 4.6L
1997 Ford F150 5.4 8 Cyl
1997 Ford F250 4.6 8 Cyl
1997 Ford F250 5.4 8 Cyl
1998 Ford Expedition 4.6 8 Cyl
1998 Ford Expedition 5.4 8 Cyl
1998 Ford F150 4.6L
1998 Ford F150 5.4 8 Cyl
1998 Ford F250 4.6 8 Cyl
1998 Ford F250 5.4 8 Cyl
1998 Lincoln Navigator 5.4 8 Cyl
1999 Ford Expedition 4.6 8 Cyl
1999 Ford Expedition 5.4 8 Cyl
1999 Ford F150 4.6L
1999 Ford F150 5.4 8 Cyl
1999 Ford F250 4.6 8 Cyl
1999 Ford F250 5.4 8 Cyl
1999 Lincoln Navigator 5.4 8 Cyl
2000 Ford Expedition 4.6 8 Cyl
2000 Ford Expedition 5.4 8 Cyl
2000 Ford F150 4.6L
2000 Ford F150 5.4 8 Cyl
2001 Ford Expedition 4.6 8 Cyl
2001 Ford Expedition 5.4 8 Cyl
2001 Ford F150 4.6L
2001 Ford F150 5.4 8 Cyl
2002 Ford Expedition 4.6 8 Cyl
2002 Ford Expedition 5.4 8 Cyl
2002 Ford F150 4.6L
2002 Ford F150 5.4 8 Cyl
2003 Ford F150 4.6L
2003 Ford F150 5.4 8 Cyl
2004 Ford F150 4.6L
2004 Ford F150 5.4 8 Cyl
Thanks again
Item Callout: 9D289
Manufacturer: Ford
1997 Ford F150 4.6L
1998 Ford F150 4.6L
1999 Ford F150 4.6L
2000 Ford F150 4.6L
2001 Ford F150 4.6L
2002 Ford F150 4.6L
2003 Ford F150 4.6L
2004 Ford F150 4.6L
Yea, emission hoses will do that, ie shed. The hose(s) actually remain in good shape as shedding doesn't effect structure flow ability. You can search around if you really want to know.
Hell, if you change that hose, you only just begun. ALL emission F/V lines under the truck, that run from front to back are in WORSE shape yet.
Yea, the black charcoal dust on the outside is normal. Normal reaction from time and what it's made of. They will continue to do they're job for years to come.
Unfortunately on my nosing around I discovered my tie rods were shot so thats another parts list to start acquiring.
I`m giving the truck to my daughter to drive back to TN and also may be pulling a single horse trailer with it also ( I have factory tow package ). I would rather replace a few items that may be iffy than possibly leave her stranded someplace over one of them possibly.Its just a dad thing about his daughter I guess.Thanks for the info on the hoses though as any info is new info to absorb.
