wont crank
Old Jul 23, 2012 | 05:46 PM
cjojr64's Avatar
wont crank
I have a 98 f150 with 4.6 motor
will not start, when turning the key all lights, buzzers and chimes work but wont crank.
I have replaced neutral safety switch,ignition,solenoid(on fire wall) and replaced the battery also had starter checked out.
truck will start when jumped from solenoid but battery light comes on and after awhile the battery dies depleting it totally. I have a short apparently between the ignition and solenoid? checked voltage on the wire from ignition to solenoid and have 0.
any help would really be appreciated.
thank you cjojr64.
Old Jul 23, 2012 | 05:51 PM
dewalt17's Avatar
Have your alternator tested. If your battery is being depleted, it is highly possible the alternator is shot.
Old Jul 23, 2012 | 05:55 PM
cjojr64's Avatar
I was going to till i drove it today and the battery died leaving me with no power what so ever (blinkers,radio, gauges) and was still able to drive it 10 mi or so till i stoped and truck and it died.
Old Jul 23, 2012 | 09:33 PM
projectSHO89's Avatar
You probably also need a new battery...
Old Jul 24, 2012 | 06:59 AM
Well, as my daughter used to say in her younger days, "DUH!"
