Changing oil filter help
Old Oct 5, 1999 | 11:13 AM
bearintex's Avatar
Post Changing oil filter help
How in the devil do you get to the oil filter to change it? Neatly? I have a '99 F150 XLT Flareside 4x4 (Electronic), with the 4.6 and automatic. I can just barely see the filter. Not like my Dad's 4x2 (Only difference). His is easy to see and get to, mounted vertically, so no mess. Mine is mounted horizontally, I see nothing but problems here. Any help greatly appreciated.
Thanks,
Barrett
Old Oct 5, 1999 | 02:12 PM
MN99F150's Avatar
Post
I have a 99 5.4l and my oil filter is in the bumper this makes it a lot easer to do, But my friend has the same truck just different color and his is mounter to the engine the only differende is that mine was made in K.C and his was made in canada. I don't think this should matter but it is the only thing that we can think of. Where was your truck made..
99 F150 Extended-Cab ORP Bright Red, Gray Interior
K&N Air Filter W/Air Box Mod
Crome Rocker Pannels
Flowmaster Exhaust Raceing Series
Access Tunnel Cover
Putco S/S Bed Rails
S/S Nerf Bars
Lund Bug Guard
GTS Headlight Covers
Pioneer CD Player
Wish List: Ram Air hood,Tinted Side Windows,Lift W/ 34" Tires, Chip, (ect.ect.)
[This message has been edited by MN99F150 (edited 10-05-1999).]
Old Oct 5, 1999 | 02:26 PM
Marv1's Avatar
Post
I went through a drive-thru oil change place last Sunday. They had me turn my wheels fully to the right so the guy in the pit could get to the filter on my 5.4.
'99 F150 SC, 4x2, Oxford white, flareside, 5.4, 3.55 rearend,
bodyside mouldings, Snugtop hard tonneau, K&N dropin and airbox mod. Duraliner drop-in (gave up on the Penda Nascar).
Future mods: 2/4 lowering, bra and some Roush stuff. Also want Gibson Supertruck
Old Oct 5, 1999 | 04:37 PM
RedFordTruck's Avatar
Post
Marv1 is correct, the wheels need to be turned to the right. One note of interest: After the filter is removed, oil will drain down onto a plate (acting like a trough or gutter). This plate is located directly below the filter and serves to guide the draining oil away from the steering linkage. However, oil will drain off to the front AND rear of the plate. Insure your used oil recovery pan is positioned correctly to catch the draining oil off of both ends.
Good Luck
Old Oct 6, 1999 | 12:33 AM
4D THNDR's Avatar
Exclamation
On my '98 4X4 the oil filter was in the bumper on the drivers side. Did they move it?
Red 99.5 Lightning,#0975,Born 5/6/99...Adopted 5/27/99 Chipped w/SuperChip Flipchip chip, Mobil 1
