Possible Vacuum Leak
Old Jun 27, 2012 | 10:45 PM
Spittin_Fire's Avatar
As many others have posted, when accelerating air switches from the panel vents to the defrost vents. I've read numerous times that it may be the vacuum check valve. I've attached a picture of what I believe to be the check valve. This valve should be a one way valve where air passes only one way. When I blow through both ends, air passes through both ways. Can someone please confirm if this is the check valve.
This is from a 2002 F-150 XLT 4.6L 2WD
Thanks in advance.
https://www.f150online.com/forums/me...-09-30-345.jpg
Old Jun 28, 2012 | 07:26 AM
Bump...Anybody...Please
Old Jun 28, 2012 | 11:07 AM
Link goes to a blank page.
Old Jun 28, 2012 | 11:20 AM
Maybe becaue I had it marked as private. I marked it as public, hopefully this helps. Is there a better way to add pictures?
Old Jun 28, 2012 | 01:37 PM
I guess I should have re-added the link. Hopefully this works.
