Lost
Lost
I need some help. I have a 2001 F150 supercrew with a 5.4. It wants to run at high idle, 1100 to 1500rpm. When I drive and get ready to stop it feels like it's still pushing. After stopping it then feels like it finally kicks down in gears. If I put it in neutral or park it then revs up to 1500rpm. I've replaced the TBS, PCV valve, cleaned MAF and cleaned the IAC and still nothing. Anyone have an idea?
[QUOTE=jbrew;4847022]Any DTC'S ? Or do you have a CEL illuminated?
If you haven't yet, get it scaned since it's free.
Sounds like you need the PCV piece back by the firewall and bhind the the plenum.[/QUOTE
I'm not real familiar with a lot of this stuff. More of a learn as I go guy. Is this piece hard to get to?
DTC = Diagnostic Trouble Code
CEL = Check Engine Light
Scan = Auto zone scans your vehicle for DTC's free. Post back what they find. Write it down.
The piece is in the back, here -
Yours is a little different , but that's where they leak. You can put your hand back there while she's running and feel for the leak.
I read the code before I cleaned the IAC. It said it was the IAC and that's why I cleaned it. Then I replaced the PCV valve and the TPS. I bought the pick up used. It has 180000 miles on it. I don't know the maintenance history. Should I just get a new IAC valve?
Yes.
Anyway could cost yuh a lot of doh replacing everything. Also DO NOT use it in the throttle body. Not on these engines unless you disassemble and know what your doing.
Colored smoke propane or Mighty vac. With a vac tool you can check the entire vac haness and PCV quickly. They're cheap. A carbon cutter for cleaning.
