Pre-Luber install
Old Sep 29, 1999 | 05:14 PM
Kraig's Avatar
Question Pre-Luber install
Has anyone installed a Pre-Luber? I have been doing some research on this, and it sounds like a engine saver. Parts cost around $500.00...
1998 XLT Supercab, 5.4L, auto, 3.55 open diff. Reflex paint. Oxford White/black bottom trim. Style Side Bone Stock...
Old Sep 29, 1999 | 07:17 PM
J-C's Avatar
J-C
Question
What do it do???
Old Sep 30, 1999 | 04:53 PM
J-C's Avatar
J-C
Post
Thanks for the description. It does sound like is has value.
1999 F-250 XLT Super Duty Crew Cab Long Bed
V-10, Automatic 4R100, 4.30 Limited Slip.
GVW = 6700# Towing Capacity = 13,300#
4 Wheel ABS disks + Reese 15K hitch
Dark Hunter Green. Ford Running Boards.
Grey Rhino-Liner. Captain's Chairs. CD+Tape
Polished Stainless Steel Wheel-well Molding http://members.home.net/jchartier/jnctrk.html
Old Oct 1, 1999 | 12:32 AM
Iggy's Avatar
Thumbs up
Sounds like a great idea!!
I haven't installed one myself, but the installation articles I've read sounded easy.
For those that don't know what it does;
A preluber is an electric pump that activates prior to starting the engine to supply oil pressure to the bearings, lifters, camshaft, etc. so you don" start a "dry" engine. Also, if you own a turbocharged engine, the pump will run for 5-10 min. after shutdown to supply oil to the turbo bearings so the oil doesn't coke and ruin the bearings.
'97 F-250 L/D Lariat S/C, 4x4, 5.4, E4OD automatic, 3.73 gears, 4 wh. ABS and 4 wh. disk brakes, gray leather interior,keyless entry w/alarm, outside: white w/gray rocker section, sliding rear window, tow package. Mods- Ford running boards, Ford ventsahdes, Color-matched bug deflector, AVS tail light covers, Tuff Liner bed liner, unknown brand of cat-back exhaust system (previous owner installed).
