5.4 L engine rebuild
Old May 24, 2012 | 07:33 PM
timco's Avatar
ok all, I'm taking my engine down to the short block. All this after my second spark plug blow out. My question is this, do I need to use a crankshaft positioning tool if my going this far. I'm at the timing chain and the book tells me that I should use it. What do you all think?
Old May 24, 2012 | 07:46 PM
jbrew's Avatar
I think you should leave it one piece and just fix the plug chambers.
Old May 24, 2012 | 08:01 PM
timco's Avatar
I've got 200016 miles on it and I'm afraid that when I'm done fixing the plug chambers the shavings from drilling them out will be down in the cylinders.
Old May 24, 2012 | 09:05 PM
jbrew's Avatar
Nah, that won't happen if you can follow direction. 200,000 miles really isn't nothing on these engines.
Old May 24, 2012 | 11:51 PM
Use a Timesert kit as per directions and don't pull the heads.
