2001 ford expedition 4.6l reb
Old May 20, 2012 | 05:27 PM
hollenamily's Avatar
i had to pull the heads off and redo the valves on the right side (passanger side) of my ford new stems new valves i have the engine out of the truck and when i put the timing marks where the book says to i can get the crank to TDC and its right but the cams are not can i turn them to make them line up like they should or did i do something wrong anyone?
Old May 20, 2012 | 06:40 PM
i think i got it but i have pressure coming out the exaust hole instead of the spark plug hole on the #8 cylinder is that a bent valve or bad rings?
Old Nov 19, 2014 | 02:24 PM
whitesamurai's Avatar
wouldnt be your rings. either bent valves, damaged valve seats (in the head) .
what test are you running ? leak down ?
Old Nov 19, 2014 | 04:05 PM
This was over 2 years ago - I assume it's fixed or they gave up.
