Please help
Old May 4, 2012 | 04:04 PM
MarauderV8's Avatar
Please help
Hello, the F150 of my brother has the follow diseases:
  • rough running
  • ticking noises
  • low mileage per gallone
  • blue smoke out of exhaust after start
i have ordered the cam phaser, hope, that will be the reason.
But today, my brother means, i have to do a test drive, because the truck has no power. and really, feels like missing of one or two cylinders.
Very bad performance. Is it possible, that the reason are the phasers?
thank you for help!
Old May 4, 2012 | 04:12 PM
EsJayEs's Avatar
Even with that vague description, it sounds like a failed cam phaser. The blue smoke at startup is likely valve guide seals. Nothing to lose sleep over.
Old May 4, 2012 | 04:23 PM
MarauderV8's Avatar
it´s. what i supposed. But will failed phaser engulf so much power??
Old May 4, 2012 | 04:30 PM
EsJayEs's Avatar
Since I have no idea how much is "so much", I can't say with certainty. But based on your short description, and the assumption that you have a 3-valve engine, it's a common failure that shares most of the symptoms you described.
But theoretically, it could be anything.
Old May 4, 2012 | 05:19 PM
year of truck?
motor size?
any codes?
Old May 4, 2012 | 05:54 PM
jethat's Avatar
Click the user CP menu and fill in your truck info so it shows up like mine in the upper right or add it to your sig or make sure every time you ask for hel you post the trucks basics or you wont get much in ther way of help..
Old May 5, 2012 | 03:14 AM
MarauderV8's Avatar
oh, sorry
2005 5.4 3V
Old May 5, 2012 | 09:16 AM
Being a 2005, are you sure that you don't have a stuck fuel injector? How many miles on the spark plugs?
Old May 5, 2012 | 09:18 AM
Originally Posted by MarauderV8
oh, sorry
2005 5.4 3V
Click link>>> https://www.f150online.com/forums/v8...ram-07m08.html
Old May 5, 2012 | 09:28 AM
MarauderV8's Avatar
spark plugs approx. 30k mls.
the truck runs w/ gas AND LPG!
and if it runs by LPG the truck don't need the injectors
Old May 5, 2012 | 09:42 AM
jethat's Avatar
So the defective injectors they put in the 2005 model year are fixed if a guy runs LPG? I dont think so..
Old May 5, 2012 | 09:47 AM
MarauderV8's Avatar
if the engine runs with LPG, the fuel injectors are out of order. LPG will injected via plastic tubes
Old May 7, 2012 | 04:46 AM
jbrew's Avatar
Originally Posted by jethat
Click the user CP menu and fill in your truck info so it shows up like mine in the upper right.
MarauderV8 - Do that so it's easier to help you. Your vehicle shows up with each post without clicking extra buttons. Easier for you and us.
Old May 7, 2012 | 04:48 AM
MarauderV8's Avatar
done
Old May 7, 2012 | 04:57 AM
jbrew's Avatar
done
I think you forgot to hit "save" at the bottom. Maybe?
