86 302 valve cover gaskets?
Old May 3, 2012 | 05:01 PM
19864X4's Avatar
1986 F150, 302 all stock with fuel injection.
Do I need to remove intake manifold to replace passenger
side valve cover gasket? Drivers side looks like I could get
valve cover out but passenger side looks like the plenum(?)
is close to top of valve cover.
Hoping someone has a trick for snaking the valve cover out
of there
Thanks!
Old May 3, 2012 | 06:15 PM
jethat's Avatar
Yep the upper intakes gotta come off. Make sure you replace the gasket on the intake. Its really not that hard to get it off.
Old May 3, 2012 | 07:08 PM
19864X4's Avatar
Thank You!
I thought it was 1 piece
Guess I never looked close enough:o
Old May 3, 2012 | 07:36 PM
jethat's Avatar
8 or so bolts. undo a few vacuum lines and linkage and its off.. Use a NEW gasket torque to the correct specifications.
