The wires are about a year old the misfire is worse when in gear and as the engine gets hotter. What I really want to know is if the computer is a possibility cause the old engine I replaced misfired on the same #4 cylinder.
I listed the causes for a missfire. I've never heard of a pcm causing a single cylinder miss..
You have a bad wire,plug,coil,injector or your compression has fallen to unworkable levels.
