01 5.4 head replacement
Old Apr 30, 2012 | 02:12 PM
captainjake's Avatar
Hi guys, I'm new here and I like the site. I recently had a sparkplug eject on my 01' 5.4L at 132,000. After reading about the problem I decided just to replace the cylinder heads. There is a company in Florida called Odessa Cylinder Head that re-man these heads with all 8 Lock-n-stitch inserts. For a $610.00 both heads and free shipping. I went this route to try to make this truck last. I'm pulling the engine apart now and heads with be here sometime next week. what all should I replace and redo while I have it apart. I got the gaskets, head bolts and new plugs on order. Should I do the timing chains, guides, and tensioners? Any hard to reach sensors that should be changed?
Any help would be greatly appreciated.
Thanks, Jake.
Old Apr 30, 2012 | 02:22 PM
1997 lariat 4.6's Avatar
id do chains, guides, and tensioners while im there. just easier to do it sooner than later.
Old Apr 30, 2012 | 02:45 PM
Scooterdog's Avatar
Didn't want a Timesert
Didn't want to do the Timesert for the blown plug?
Old Apr 30, 2012 | 09:14 PM
Could not do time-sert, Previous owner already had fixed with a hellicoil. The hole is very out of round like a teardrop, possible crack. The way my luck works it would blow another sparkplug in the middle of nowhere. I guess Lock-n-stitch is the ford approved fix. I figure if I buy the timesert kit and the double oversize kit it could fix it, but if not i'm in a head anyway. Local machine shop wanted 50 bucks per sparkplug hole. Not including get the heads to spec.
I will take photos of the head once it's off the truck and the new ones. Maybe some photos of the process. I can post them on the forum.
Old May 2, 2012 | 05:56 AM
jbrew's Avatar
This is kinduh crazy. A 20 min fix done the hard, long and expensive way.
Could have rented the kit that works. -
https://www.f150online.com/forums/ch...rs-galaxy.html
And/or used a double or triple sert if needed -
http://www.pendergrasstool.com/kits/spark_plug.htm
All you had to do was ask.
Old May 2, 2012 | 08:22 AM
Veteran: Army
lets hope that company uses short inserts and aluminum ones at that
