96 F150 Check Engine.
Old Apr 11, 2012 | 08:48 PM
hutch58's Avatar
96 F150 with straight (300?) six. Ran it hot (STUPID) and cracked the head. When head was replaced I opted for a cheaper (low port?) head. Now I have a check engine light and am told it is a result of the other head.
Is there anything barring replacing with the stock head (not an option) I can do to resolve this issue. The truck has 129k miles but is clean and nothing else wrong mechanically.
Feel it has something to do with emission, possibly a vacuum hose needing to be either plugged or ????
I'm wanting to sell the truck but need to get the check engine issue corrected.
HELP!
Old Apr 12, 2012 | 03:04 AM
What's the trouble code?
Old Apr 12, 2012 | 08:32 AM
adrianspeeder's Avatar
Howdy and welcome.
Pull the trouble codes. 96's are OBD2, so any autozone or cheap scan tool can do it.
Adrianspeeder
Old Apr 17, 2012 | 05:28 PM
hutch58's Avatar
Went to Advance and the scan returned the following codes:
> P0443 - Evaporator Emission System Purge Control Valve Circuit.
> P0411 - 2nd Air Injector Incorrect Flow.
Thanks.
Old Apr 18, 2012 | 09:11 AM
Rockpick's Avatar
Moderator &
Moving this thread up to pre-97 in an effort to keep the answers rolling...
Old Apr 18, 2012 | 09:12 AM
Rockpick's Avatar
Moderator &
Now moving to Engines.
Old Apr 23, 2013 | 11:57 AM
hutch58's Avatar
Check engine light on 96 'straight' 6cyl
Note this is NOT a V8 engine..this is the straight 6.
Recap...ran hot and cracked head. Replaced 'high port' head with a 'low port' head ($100 cheaper). Now the Check Engine light comes on. Here are the codes returned @ Advanced:
I have plugged the vacuum hoses open out of the emission 'module'. Check engine went away for about 100 miles and reappeared w/ same codes.
The 'low port' replacement head I had installed apparently does not have the same emission connections the 'high port' head.
Is there any way to bypass the emission system to eliminate the Check Engine light f/displaying.
Thanks.
Old Apr 23, 2013 | 03:43 PM
jbrew's Avatar
You started this thread over a year ago ?
Old Apr 23, 2013 | 05:09 PM
hutch58's Avatar
No resolution
correct...and still no resolution. Truck is driven 50 miles a month....maybe.
Old Apr 24, 2013 | 01:29 AM
Geez - if all you want to do is sell the truck, pull the bulb and play dumb.
I don't think the evap code is related to the head, you probably do have a legitimate evap issue. The AIR code is a different story, something isn't right with your smog pump plumbing.
Old Apr 28, 2013 | 08:35 PM
hutch58's Avatar
Sorry...wouldn't want someone to "pull the bulb and play dumb" with me.
Integrity....what you do when no one is looking !!!
Old Apr 28, 2013 | 10:41 PM
I would not have suggested that with a newer vehicle. You have a bit of a Frankenstein there.
