Towing Group question...
Old Sep 3, 1999 | 05:01 PM
FordLover's Avatar
Question Towing Group question...
I noticed on the 5.4L trucks, they have a towing capacity upwards of 8,000 lbs. However, the towing group only includes a Class III hitch, rated at 6,000 lbs. What's the deal here? Is it better to add a Class IV hitch later? I know the Rams come with a Class IV hitch....
Also, what's the difference between the H.D. shocks in the tow group and the H.D. shocks in the ORP? Or are we paying for these twice if we get a truck with ORP + tow?
Old Sep 3, 1999 | 06:12 PM
J-C's Avatar
J-C
Cool
I can't answer your first question, but when I ordered my truck with "overlapping" option packages, I was only charged for the portion of the packages that didn't overlap.
You won't be paying twice
I think the only difference in the shocks are that the ORP shocks are longer.
Good luck!
Old Sep 4, 1999 | 01:05 PM
dogcam's Avatar
Post
FordLover, do you or are you getting the 5.4L with the tow package? its rated for 8500# and I don't know how you got your rating info, but a class 3 hitch is what you want for pulling a weight over 5000#s.
I have one now(97) and getting same (00), transmission,engine cooler and bigger radiator, forget what the package #is, but check out your info, it's all in the Ford magazines at the dealers.
That 5.4 with the trailer package will pull a house over...
I am talking about a 4X2, just think what a 4X4 would do???
Dogcam
dogcam@myf150.com
97 Lariat s/c 4x2 5.4
all mods off, turning it
in for a new 00
Old Sep 7, 1999 | 03:39 PM
FordLover's Avatar
Unhappy
Dogcam,
The hitch itself states that maximum towing capacity is 6000lbs. It seems like a 7000lb. trailer would not be safe for this hitch, although the truck is capable of towing it.
Old Sep 8, 1999 | 02:32 AM
V10 man's Avatar
Smile
I believe that the weight ratings on the hitches are dead weight. If you use a weight distributing hitch it doubles the capacity. 500/5,000 would be 1,000/10,000.
Old Sep 8, 1999 | 09:28 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post
Also, a chain is only as strong as it's weakest link.
I saw two identical 2" *****. One was rated 6000lbs the other 3500lbs. The only difference was the threaded shaft. One was 1" the other 3/4".
Old Sep 9, 1999 | 12:22 AM
birddogg's Avatar
Post
i know people who like the longer shafts...mine does the job for me...thats what counts
Old Sep 9, 1999 | 12:44 AM
Lee's Avatar
Lee
Post
Same size ***** .. different size shafts .. different ratings .. The smaller the shaft the lower the rating, size does count.
99 XL SC 4.2 3.31 automatic
[This message has been edited by Lee (edited 09-08-1999).]
Old Sep 9, 1999 | 01:03 AM
Mark G's Avatar
Post
Raoul,
Are you alright?
These last three posts hit me as being entered with the wrong names or something.
Take care,
Mark
Old Sep 9, 1999 | 10:16 AM
Iggy's Avatar
Exclamation
My truck is rated to tow 8300 lbs. Max tongue weight is 500 lbs and 800 with a weight distribution system.
'97 F-250 L/D Lariat S/C, 4x4, 5.4, E4OD automatic, 3.73 gears, 4 wh. ABS and 4 wh. disk brakes, gray leather interior,keyless entry w/alarm, outside: white w/gray rocker section, sliding rear window, tow package. Mods- Ford running boards, Ford ventsahdes, Color-matched bug deflector, AVS tail light covers, Tuff Liner bed liner, unknown brand of cat-back exhaust system (previous owner installed).
Old Sep 9, 1999 | 10:24 AM
Raoul's Avatar
25 Year Member
Post
Just being a nice setup man.
Like a pitcher during the homerun derby at the All Star game, serving up meatballs so these wanna-be Mark Mcguire's can hit some out.
Old Sep 10, 1999 | 12:32 AM
Lee's Avatar
Lee
Post
Thanks Raoul ... the setup was appreciated.
