5.4L Van and F150 engine the same?
Old Mar 13, 2012 | 10:24 PM
boosted_d16's Avatar
Okay guys, my 5.4 in my '03 F150 took a dump this week and a found a guy local with a 35,000 mile re-maned 5.4L that came out of a '99 Van. Is this the same engine in my F150? I mean I know the motor mounts and accessories will obviously be setup different but is the oil pan, transmission bolt up, all that major stuff the same?
Old Mar 14, 2012 | 12:39 AM
Toyz's Avatar
I believe the 99 van was non PI. Your engine has the PI (performance improved) heads. In the trucks, the 99 was the first year of the PI design. About a 25hp difference. But I believe they came later in the vans. They are the same, and swappable with minimal parts swapping but there was a PI version and non PI version.
Old Mar 14, 2012 | 08:14 AM
Okay after some research I did come across the PI vs non PI heads. How do I tell if this 5.4 has PI or non PI heads??
Old Mar 14, 2012 | 08:17 AM
MGDfan's Avatar
Refer to the pic - see the 'PI' after the number?
http://www.ford-trucks.com/forums/sh...56&postcount=6
Props to Phil fer supplying the info!
Old Mar 14, 2012 | 09:39 AM
Toyz's Avatar
Specs show the 99 van 5.4L with 235hp, which would be a non PI engine. The PI engine had 260hp.
Old Mar 14, 2012 | 01:50 PM
Okay so this motor isn't a PI engine from the van, however it is really clean and I can get it for a steal. It has the intake manifold and all other accessories on it, but can I use my old engine harness and ECM without an issue or would I have to get the ECM for the non PI engine?
