Major engine work
Major engine work
2005 FORD F-150 5.4L V8 SOHC
Ignition : Ignition CoilRelated Parts
MOTORCRAFT Part # DG511 {#3L3Z12029BA} B
$43.79 $350.32
Fuel/Air : Fuel InjectorRelated Parts
MOTORCRAFT Part # CM5138 {#5C3Z9F593DC, CM5091}
5C3E-9F593-DB D
$27.79 $222.32
Engine : Timing SetRelated Parts
CLOYES Part # 90391SB Includes: Crank, Chain (2), Tensioner (2), Tensioner Arm (2), Guide (2) C
$185.79 $185.79
Engine : Timing Cover Gasket SetRelated Parts
FEL-PRO Part # TCS46078
Repair sleeve not incl. A
$39.79 $39.79
Engine : Timing Cam SprocketRelated Parts
DORMAN Part # 917250 AC
$139.79 $279.58
All of these parts are from Rock Auto web site. I plan to replace COP'S, injectors, timing chains & related parts. Question: the timing cam sprocket part, does that include the phasers? It only shows one of these so I need two, correct? Is there anything I am missing to do this job? Are these the best parts to use and is this the best price for these parts?
Thanks for your help and any hints on doing these jobs is appreciated!
$43.79 $350.32
5C3E-9F593-DB D
$27.79 $222.32
$185.79 $185.79
$39.79 $39.79
$139.79 $279.58
They phaser includes the cam sprocket. It is not sold separately from the sprocket.
The part number is 3R2Z-6A257-DA and you can find them new on ebay for $110 each.
The injectors look like about the right price. I think you can get them for about $26 each at http://www.silverstatefordparts.com/
On the coils you can get 8 Visteon DG511's on amazon for $123.00 including shipping. I have them on my truck and they work great.
Oh also for the gasket and timing kit you look at
http://stores.ebay.com/REDLINE-Engine-Supply
on ebay. Great price and quick shipping.
I checked on a set of injectors on ebay. They were advertized for $159 for a set of 8. The discription said new but, if you read on it also says they could be "factory seconds" or they could have "defects". WTF!!! I emailed the company and the response from them was to go buy them at the dealer if I wanted a warranty. They never did answer the question if they were new or not. Guess ebay is not the place to get this part. I wonder how many people they sucked in with the false advertising or should I say the deceiving wording discribing these injectors! Above "Electron-Jack gave some suggestions, anyone else have suggestions where to get the above listed parts that are reliable "NEW" parts at a cheaper price than Rock Auto or is this the best place and the prices are not to high? Thanks for any help with this.
