Hard starting/ bad fpdm?
Old Jan 9, 2012 | 08:37 AM
shope7's Avatar
Could a malfunctioning fpdm be causing my hard starting issue? I have inspected it and it appears ok. That is, it's not corroded or cracked or anything like that
Old Jan 9, 2012 | 11:29 AM
jethat's Avatar
Fuel pump driver module? I think it would work or not. Fuel filter lately? Do that and then test the fuel pressure..
Old Jan 9, 2012 | 11:33 AM
kevhead75's Avatar
It could be the FPDM but also could be lots of other things. Jethat suggested fuel filter which is a good start. Any codes? what kind of maintenance has been done? Might be time for plugs.
Old Jan 10, 2012 | 08:51 AM
shope7's Avatar
Have tried all that and more, everything you can think of. One mechanic I took it to thinks it might be the fuel pump starting to go out
Old Jan 10, 2012 | 09:59 AM
jethat's Avatar
You would be able to verify how the pump is working with a fuel pressure test..
Old Jan 23, 2012 | 07:06 PM
shope7's Avatar
mystery solved
well after exhaustive research and trying everything i cud think of, my parts guy suggested, and also someone on this site who's name escapes me, that it was a sticking fuel injector and voila, its starting like it was brand new again. thanks for the help everybody
Old Jan 23, 2012 | 10:47 PM
Contender's Avatar
Glad to hear it.
Fill us in on the details. How did you figure out which injector? Did you just begin replacing parts?
Old Jan 25, 2012 | 08:39 PM
shope7's Avatar
how
oh, sorry. I was periodically getting a code for #7 misfire. the guy who mentioned that it cud b a leaking injector was GLC by the way
