07 5.4 pinging noise (with sound clip)
Hi,
Anyone know what the noise is in the sound clip? I hear it when the truck is running or for a bit after I turn it off. I am thinking maybe it is the exhaust from being hot, not sure. It's like loud metal pinging noises.
Here is an audio clip, you can here two real good ones. This is with the engine off. Click here for audio clip
Cat's cooling down. In most cases it is normal, which yours sounds like. If it was excessive, I would inspect the cats to make sure theyre not plugged and glowing red. But there are other running conditions that would indicate that. So I would consider it normal.
