engine problems...help!
Old Jan 7, 2012 | 01:08 PM
seger25's Avatar
I have a 98 ford f150 4x4 5.4 liter and I need a new engine...what other ford truck engines are compatible with my truck?
Old Jan 7, 2012 | 10:08 PM
Toyz's Avatar
Pick up a 5.4L (performance improved heads) from 99-03 F150. The only other engine that is close to a direct swap is the F150 4.6L, which has less power so that would not make sense. Low mileage 5.4L 99+ would be ideal and a direct fit/swap minus some minor swapping of accessories.
Old Apr 25, 2013 | 09:41 AM
Phil F-150 06''s Avatar
06' King Ranch
My truck has 95ish thousand miles and yesterday an a military transfer across country, the engine blew up. The dealership said the crankshaft barrings were worn out and that caused the crankshaft to slip back and forth thus causing a knock. In a short amount of time that knock led to the rear seal blowing out and loss of oil pressure. I called the Ford 800 number and expressed my concerns with the engine problems and the best answer they and was.......sorry that happened. I told them I wasn't happy with that answer and if that is the best they have, I am no longer a Ford guy!
From reading this blog, there are several issues ranging from plugs to valves leading to a host of concerns that seem to go unanswered by Ford Motor Company. If I buy a $40K truck, I expect to at least get 200K out of the engine before there are major issues.
Bottom line--I think there needs to be some sort of recall on the 5.4l engine. Ford needs to make this right if they want to keep my business!!!
Old Apr 25, 2013 | 10:22 AM
It really sux that happened.....but Ford isn't going to rectify anything by you posting in all the problem threads on this forum....
Old Apr 25, 2013 | 07:16 PM
Toyz's Avatar
Sucks to have to go through that but those type of unforeseen things happen in every engine. With the ford modular, you are 1 in a handful that experience catastrophic damage like you have vs the 10's of thousands or more that do go 200+k
