2006 3v head removal or problem solving
Old Jan 12, 2012 | 03:14 AM
code58's Avatar
Originally Posted by jgger
If it was running lean enough to fry the ground strap off of the plug, then it probably started to put a hole in the piston. Once the plug died there was no more fire or heat to damage the piston any further. When the new plug was put in the fire came back and finished melting a hole in the piston.......probably started to go down hill from there.
But that's just my guess.
We have a winner! I'm betting the same thing. I don't think anything he did damaged it, it was already history from detonation of some source. The fact that the plug had oil on it when he took it out and that cylinder was misfiring tells the story. Give the guy a break, I believe he's the innocent bystander in this story.
