engine problem? not sure
Old Dec 2, 2011 | 03:04 PM
GatorBoi's Avatar
well this has been happening a lot lately. I'll be going to accelerate and it feels like its fine then it starts to feel like its pulling back. Happens at all different times weather its cruising or accelerating. I put it in 2nd gear to see if it would do it there to and it does.
I've already changed the plugs,cops and fuel filter. Any advice? 07 4.6L
Old Dec 2, 2011 | 03:06 PM
Clean the maf and tb......the how to section of the forum has articles on these procedures....
Old Dec 2, 2011 | 03:47 PM
GatorBoi's Avatar
alrighty im not that engine smart so where exactly is the MAF. I know the TB.
Old Dec 2, 2011 | 04:19 PM
kevhead75's Avatar
Mass Air Flow sensor. Usually located on the air intake. Measures how much air is coming in the intake, temp, barometric pressure.
Old Dec 2, 2011 | 04:55 PM
Scooterdog's Avatar
COP's
If after the MAF and TB cleaning. next comes a new fuel filter. If that still does not fix it, it will most likely be a bad COP(s) [Coil On Plug].
But do what 88 said first.
Old Dec 2, 2011 | 05:00 PM
GatorBoi's Avatar
ok i just picked up some cleaner for both. I'll tackle this tomorrow morning.
If this still occurs, what next? I've already replaced all 8 cops and plugs, fuel filter and air filter.
Old Dec 2, 2011 | 05:14 PM
Click links>>>https://www.f150online.com/forums/ar...ttle-body.html
https://www.f150online.com/forums/ar...005-5-4-a.html or https://www.f150online.com/forums/ar...ml#post4193148
Old Dec 2, 2011 | 05:22 PM
Scooterdog's Avatar
COPs
Did this problem occur anytime AFTER you replaced the COPs?
How many miles? any CEL? (codes)
Old Dec 2, 2011 | 06:10 PM
GatorBoi's Avatar
well i was getting a misfire so i replaced the plugs. Still kept getting a misfire and replaced the cops. Fixed the misfire. changed the air filter and fuel filter due to regular maintenance. All the while it was doing this even before i changed everything. So at first I figured it was possible the misfire that was doing it but after i fixed it it still kept doing it. So hopefully when I clean the MAF and TB tomorrow it will stop.
Old Dec 2, 2011 | 06:12 PM
GatorBoi's Avatar
No more codes are being thrown after I fixed the misfire with new plugs and cops.
