Another heating problem
Old Nov 24, 2011 | 07:21 AM
TheSauce05's Avatar
Sorry to post something else about heater cores and such, but I've searched and can't find exactly what I'm looking for. Just replaced a leaking heater core in my 2000 F150 4.6L. Before replacing, I had great heat, just a bad smell of antifreeze. Now, I have little to no heat. Every once in a while it will get warm, but usually stays cold. Seems like it only gets warm when it's sitting still and I rev the engine. While driving it doesn't get hot at all. The other day I was driving home and the engine overheated, so I immediately changed the thermostat thinking that it was also causing me to have no heat. Put in 2 gallons of 50/50 coolant and still have no heat. I can still hear the sound of liquid moving when I first turn on the engine and give it gas, but it goes away after just a minute or so. I'm thinking either I still have a good amount of air in the system and need to burp it and add more coolant or my water pump has decided to take a dump. The truck has 130,000 miles on it, so it wouldn't be a big surprise, just curious if anyone has a more solid idea about what's going on. Any help or advice is greatly appreciated!
Old Nov 24, 2011 | 07:24 AM
TheSauce05's Avatar
I feel I should also add that the first time I changed the thermostat (about 2 years ago, and that time the thermostat had actually managed to get itself wedged and took a good amount of prying to remove) I had a good amount of coolant left in the upper rad hose. This time I had none. I had just changed the heater core a couple of days before, so I know it wasn't low on coolant.
Old Nov 24, 2011 | 11:56 AM
You are airlocked.
Old Nov 24, 2011 | 12:08 PM
TheSauce05's Avatar
Well, guess I'll try to find a decent place to burp it, then. I may decide to go ahead and change the water pump this weekend anyway. Thanks for the reply
Old Nov 24, 2011 | 12:49 PM
jbrew's Avatar
Since your not posting in the right forum, you most likely haven't searched all that effectively
The correct forum - https://www.f150online.com/forums/hvac-69/
Don't post there now, that would be double posting. That's worse than.
A Moderator can move your thread for you tho, - if you want to email one.
Check the pump for wobble, coolant around the weep hole or a bad T-stat. They perform the best with the 192's and 194's.
Hard to Burp, use the procedure below -
Old Nov 24, 2011 | 01:11 PM
TheSauce05's Avatar
Thanks for the reply and useful info. I did see the HVAC forum when searching, but for some reason didn't see it when I went to make this thread. Now I see that I didn't look down far enough. I will grab a couple more jugs of coolant tomorrow and try to get the air out of it. Luckily work is only a couple miles away, so the truck doesn't get too hot back and forth from home.
