Vacuum issues? Or something more...
Old Nov 1, 2011 | 04:22 PM
Jay_Dubb's Avatar
I have a 7700 series F150 with 95K miles on her. For the last couple months I've noticed an odd whirling/gurgling noise from under the hood...and the noise was consistent with engine RPM. Within the last week or so I've noticed that when I brake hard and the truck comes to a stop (at low RPMs - less than 1500) the brake pedal starts to vibrate slightly as if the ABS was kicking in. I initially thought the master cylinder was going on me...than this winter storm hit us hard and I was unable to switch into 4WD. I'm thinking I have a vacuum issue more than a master cylinder issue...any recommendations on how to check to see if I have a vacuum leak that is creating chaos in systems that are dependent on vacuum to run properly, such as the IWE solenoid and brake system??
Old Nov 2, 2011 | 07:23 AM
enriched's Avatar
it may need some ole fashioned maintenance...sometimes the actuators get sticky.... or build up on the front shaft. if it has a vacuum leak it should run poorly. its gonna have to get under it and check some things out
you may have a warped rotor
Old Nov 2, 2011 | 12:36 PM
Jay_Dubb's Avatar
ok thanks...Not sure how the circuit works but I should have noted that the light isn't illuminating on the dash...normally I hear two clicks then the light comes on. I only get one click now and the LED doesn't come on
Old Nov 2, 2011 | 01:03 PM
You don't have IWE, you have a front diff lock.
